How much boost is safe??
volvee850glt
- Year and Model: 1997 850 GLT
I'm pushing about 7psi right now but Iv'e seen places on the internet where people say 850's push 10psi stock. I recently had the head rebuilt and the guy that did it said he wouldn't go over about 7psi with the standard valves. How much boost would be safe with the standard valves??
'97 850 GLT- mbc, custom rip, custom cold/ram air intake, OBX turbo back performance exhaust.
rbodor3
- Year and Model: 01 S60 LPT
- Been thanked: 2 times
you're leaving out a lot of information
what all was rebuilt on the head? did you get an angle valve job done? Has the block been rebuilt?
What turbo are you running, stock? How much mileage on the engine? What ECU are you running, stock?
There really is no answer to this question - it's not really the quantity of boost that will bend your rods, it's when you get it, how much at that time, what gas you're running, etc. etc. etc. etc. etc.
The easy answer is 15psi
but if you build more than 7 below 3000 rpms you're looking at detonation.
If you run bad gas you're looking at detonation.
If you boost spike you could get detonation, blow out, crap out your rings, etc.
01 Volvo S60 2.4T
- 8211 Views
Last post by bmdubya1198
- 18 Replies
- 10212 Views
Last post by erikv11
