s40 2004, engine keeps shutting off..
1996 - 2004 S40
1996 - 2004 V40
deepshit
Year and Model: s40 2004
Post by deepshit »
Just bought engine shuts off after every 3 -4 blocks. local mechanic computer scans comes up: code 43... turbo hose malfunction. whateles might be the problem?
xb corp
Year and Model: 855GT5 '96
Post by xb corp »
little confused here...describe first which model your car is;
s40 with 4cylinder or s40 with 5cylinder?
here in Malaysia, the dealer sold older ph2.5 s40 till march 04 and then in oct they launched the newer s40..
ok. if its the older s40 (4cyl)..check your idle air pump/valve. it is located right infront of the throttle body with FORD logo on it. clean it with t/b cleaner and check the hoses as well.
'96 855GT5 324hp 386lb-ft
Nissan 16V turbo, HKS w/g, SS 2.5" d/p+FGK 3" exh, HKS Evo9 FMIC+2.5" piping, K&N, Apexi BOV, NA cams & t/b, portd head, 5 sub-injctrs, Mocal coolers, AMG 4pot 325mm, AVS 18", Bilstein B6/Vogtland
