940T Miss at idle
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
VTPOLAR
Year and Model: 1993 940T
940T Miss at idle
Post by VTPOLAR »
My 940T has a miss only at idle. Thought is was MAF, did not fix a thing. If MAF is disconnected, the miss cleans up. When cold, miss isn't there, within one minute it is present. Any ideas?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked for fault codes?
Attached is a list of other things that can cause erratic idle.
940 erratic idle1.pdf
(38.61 KiB) Downloaded 80 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
VTPOLAR
Post by VTPOLAR »
No I have not. The MIL has not been on. Could there be fault codes stored without MIL on? I appreciate your help! I will do a little more poking around.
billofdurham
Some fault codes can set without the MIL coming on. If I have a problem with my car I check for codes as a matter of course.
Bill.
Previously:
