3rd row seat install ??
bigdaddy
Year and Model: 1998 v70
Post by bigdaddy »
Does anyone have a link that works w/ install instructions for a 3rd row seat in a 1998 v70?
Thanks
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There was a great writeup on VS but I can't seem to find it at the moment.
Vtrader
Year and Model: volvo 850
Post by Vtrader »
I posted some videos on youtube how to do it, take a look I think there are 6 videos
good luck
Patrick
2007 volvo v70r electric silver | 2005 volvo s60 T5 6 manual w/aero kit
bobice
Year and Model: XC70 1999
Post by bobice »
The videos are great. But my seat belts are stuck and couldn't be pulled at all. How to do with it?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I will ask my mechanic later how to release it
bobice
Post by bobice »
Finally I figured that out, the belt is stuck because it retracted too much. The procedure is simple: 1, open the side without the label, 1a, push out two little pins with a wire/big needle; 1b, Use flat-head screw driver to pry open the other two pins.
2, Pull the belt while pushing the little plastic that hold the wheel to rotate in one direction. After pulling a little out, the belt can then be pulled out freely.
slmcm05
Year and Model: 2004 XC70
Post by slmcm05 »
Reviving an old thread, but thank you for the tips on the seatbelt. I'm currently installing my third row and my seatbelts had also locked-so frustrating. I was able to fix it with your help.
slappytg
Year and Model: 2003 xc90
Post by slappytg »
I can't get my belt unstuck for the life of me. I did what you said but do I press down on the small circle ?
Has thanked: 311 times
Been thanked: 818 times
slappytg I know this doesn't answer your question sorry, but this thread needs a link to the complete install guide: viewtopic.php?f=1&t=49056
Has thanked: 1611 times
Been thanked: 4072 times
Old thread alert
Be careful routing the heater wire harness, if so equipped.
