S40 2005 Key Keeps Getting Stuck
shelly4278
- Year and Model: s40 2005
My key is getting stuck. After I move it back and fourth it comes out. I know I have to take it to the dealership. I do have an extended warranty on it. Will it be covered. is this a major issue. Please help!
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Try squirting some WD40 into the lock opening.shelly4278 wrote:My key is getting stuck. After I move it back and fourth it comes out. I know I have to take it to the dealership. I do have an extended warranty on it. Will it be covered. is this a major issue. Please help!
shelly4278
will that be covered if I have an extended warranty????
Depends on what extended warranty you have. I have a bumper to bumper extended warranty which "should" cover it. I can fix almost anything on the car (with my freinds help -ex mechanic) except the "computer". So I paid more for the ONLY covererage that paid for the computer. It covers everything except "expendibles" ie brakes, lights, spark plugs, wipers and the like. I bought a 2007 V50 with 69k and a 36 mon / 36k "bumper to bumper" extended warranty.
If you unsure of coverage call them to ask. IMHO it should be covered - cant quote me on that.
Jim
Jim
coustyj
2007 V50 Silver Metallic / 73,055 K
Volvo 1 - 1994 850 / Gray / 176,789 rip
Volvo 2 - 2000 V70 SE / Moondust / Manual / 169,892 rip
shelly4278
Thanks I will contact the dealership.
shelly4278
I took the car to the dealership. They said I need a new key cylinder. The part is about 500 dollars to fix. The key does come out. Any ideas to avoid getting this replaced? Help
vegasjetskier
See my other post above. Have you tried it?shelly4278 wrote:I took the car to the dealership. They said I need a new key cylinder. The part is about 500 dollars to fix. The key does come out. Any ideas to avoid getting this replaced? Help
shelly4278
I asked a Volvo tech today and they said not to spray anything in it. Has this happened to your Volvo??
vegasjetskier
Nope. Has not happened to my Volvo. However, based on other jobs I have done, I know that a little lubrication often helps a lot. I live on the beach and often the lock cylinders to my house will become sticky, sometimes not working at all. A squirt of WD40 and few rotations of the lock and they're working again smooth as a baby's bottom.shelly4278 wrote:I asked a Volvo tech today and they said not to spray anything in it. Has this happened to your Volvo??
It looks like you have nothing to lose. Listen to the Volvo tech and pay him $500 for a new cylinder, or try some lube and maybe not have to buy a new cylinder. If the WD40 doesn't work, you can always buy the new cylinder.
