Just bought a 2000 S80 T6 and was doing some typical maintenance. As I was pulling out the Trans Dip stick the surrounding plastice and rubber just crumbled.....pieces went into the refill tube. I tried to get all the little pieces out but am just a little fearful that some may have fallen all the way in. My first thought is do a transmission change, but what would I need to do to make sure all little particles are removed? What do you think? Any suggestions would be helpful..... Oh great now my check engine light is on, But the car drives fine.
Thanks
Transmission
Joeginator
- Year and Model: S80T6 2000
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
The particles will be trapped by the filter, so you should be OK. I recommend a fluid and filter change anyway, if you haven't done it before.Joeginator wrote:Just bought a 2000 S80 T6 and was doing some typical maintenance. As I was pulling out the Trans Dip stick the surrounding plastice and rubber just crumbled.....pieces went into the refill tube. I tried to get all the little pieces out but am just a little fearful that some may have fallen all the way in. My first thought is do a transmission change, but what would I need to do to make sure all little particles are removed? What do you think? Any suggestions would be helpful..... Oh great now my check engine light is on, But the car drives fine.
Thanks
- 13 Replies
- 2910 Views
Last post by TJWookiee
- 1527 Views
Last post by allehagelnjuif
