Long time reader, first time poster.
I have been watching pull a part lots for a 2005 V70 2.4L automatic transmission from a Volvo. I have not been able to find one anywhere near me.
All that being said, I know that Aisin makes the same transmission, AW55-50SN, for other make and models. Here locally, there is a 2004 Nissan Quest minivan on the lot. I could get the transmission for 125.25 with a 6 month warranty. So this is why I am tempted.
While it is tempting, I was wondering if anyone was crazy enough to try and put a non-Volvo transmission in their car. I am sure it is not a possibility but just seeing if it would be an option or if anyone has been crazy enough to try it.
2005 V70 Auto Transmission Swap with non Volvo transmission
precopster
- Year and Model: Lots
- Been thanked: 128 times
The AW55-50SN comes in so many different builds that I wouldn't even put one in from the same MODEL and YEAR of Volvo unless I searched the VIN of both cars on Vida for compatability.
Swapping transmission from one make to another can be done with some vehicles (I swapped a Toyota AW-341E into a Volvo 960 last Summer, but detail differences made the swap a bear of a job) however these new cars are so tightly controlled by their transmission computer that using anything but the right transmission won't work.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The bell housing does not unbolt from the aw 55-50 gearbox. You can't use one from another make as they do not use a standardized bolt pattern. Even with the same manufacturer the bolt pattern for different engines is not always standardized.
allehagelnjuif
- Year and Model: 2005 V70
Thanks for the replies Mike and Jimmy. Sounds like the cost definitely outweighs the benefit. I will just sit patiently and wait for a 2005 Volvo to pop up.
- 1819 Views
Last post by mf70
- 1292 Views
Last post by Roger_850T
- 1421 Views
Last post by allehagelnjuif
- 12 Replies
- 3478 Views
Last post by CNGBifuel
- 2012 Views
Last post by bonosall
