Resetting Maintenance Reminder Lights
hammers80
Year and Model:
Post by hammers80 »
My wife just picked up a 2005 S80 and I plan on doing my own oil changes. Does anyone know how to re-set the service light reminders? Thanks in advance.
Richard Stern
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
Also -> Amazon link
hammers80
Year and Model:
Post by hammers80 »
Thanks a bunch....btw what is a "day counter reset button"?
Richard Stern
stalban
Post by stalban »
Did you ever receive a respone on that last question?
RLSELF1111
Post by RLSELF1111 »
Try this....I found it under other volvo information.....
All models for 1999 and on can be reset by putting the ignition key into position I, push in and hold the odometer reset button (use your left hand), move the ignition key to position II, when the service light begins to blink,let go of the odometer reset button. Confirm by turning your Volvo off then on again.
PAWAVE
Post by PAWAVE »
This does not work on my 2001 S80? Anyone know how to reset the service light on a 2001
RLSELF1111 wrote:Try this....I found it under other volvo information.....
:cry:
s80t6owner
Post by s80t6owner »
The above should work. I have done is several times on my 2001 S80. Make sure you are holding the odometer and not the clock reset button.
S80 2003 Owner
Post by S80 2003 Owner »
I cannot reset the routine maintenance meassage on a 2003 S80 T6 that comes up every 7500 miles. Anyone know how to reset this message?
Big Steve
Post by Big Steve »
s80t6owner wrote:The above should work. I have done is several times on my 2001 S80. Make sure you are holding the odometer and not the clock reset button.
This procedure does not work on mu UK early 2002 S802.4 Bi-Fuel model.
I was absolutely certain to use the odometer button but it does not reset.
Does anyone know how to do this for these later models?
sam_2002_s80
Post by sam_2002_s80 »
I have a 2002 volvo s80 and the "time for regular service" light is on dose anyone know how to reset it? Also I have the "srs service airbag urgent" light on I need help reseting it. Thank you.
