Resetting Maintenance Reminder Lights
My wife just picked up a 2005 S80 and I plan on doing my own oil changes. Does anyone know how to re-set the service light reminders? Thanks in advance.
Richard Stern
- Has thanked: 2656 times
- Been thanked: 1248 times
This should do it:
https://www.matthewsvolvosite.com/reset.php
RLSELF1111
Try this....I found it under other volvo information.....
All models for 1999 and on can be reset by putting the ignition key into position I, push in and hold the odometer reset button (use your left hand), move the ignition key to position II, when the service light begins to blink,let go of the odometer reset button. Confirm by turning your Volvo off then on again.
PAWAVE
This does not work on my 2001 S80? Anyone know how to reset the service light on a 2001
RLSELF1111 wrote:Try this....I found it under other volvo information.....
s80t6owner
The above should work. I have done is several times on my 2001 S80. Make sure you are holding the odometer and not the clock reset button.
S80 2003 Owner
I cannot reset the routine maintenance meassage on a 2003 S80 T6 that comes up every 7500 miles. Anyone know how to reset this message?
Big Steve
This procedure does not work on mu UK early 2002 S802.4 Bi-Fuel model.s80t6owner wrote:The above should work. I have done is several times on my 2001 S80. Make sure you are holding the odometer and not the clock reset button.
I was absolutely certain to use the odometer button but it does not reset.
Does anyone know how to do this for these later models?
sam_2002_s80
I have a 2002 volvo s80 and the "time for regular service" light is on dose anyone know how to reset it? Also I have the "srs service airbag urgent" light on I need help reseting it. Thank you.
