95 volvo 850 non turbo
Hilda95
Year and Model: 95 volvo 850
Post by Hilda95 »
Nice day in pittsburgh today it hit 85.. My 850 started to stall coming up on a slow down or stop.
Temp gauge is fine car has ran great.. love the car Not sure where to start.. it starts right up
and runs good afterwards.. could it be cause of the warm weather??? please help
Joe Hurless
Year and Model: e36 328is
Post by Joe Hurless »
Check the air hoses and boots for tears. An airflow leak is a common cause of your problem. After that I would check the fuel pump and relay.
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
as joe says, it sounds like a hose tear or vac leak. When was the last time its had a good ol tune up ? how many miles on the car ? etc..
1996 Platinum Edition
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Codes?
Without codes the best we can do is guess. If you have not used your OBD system here is how the codes are read.
http://volvospeed.com/CheckEngine.php
Since you have an N/A pull the codes from both port A-2 and A-6 and post back the results.
The fuel pump relay, when it starts to fail, is temperature sensitive and it may or may not post a code at all. We are at that time of the year.
jonofmac
Year and Model: 1994 850
Post by jonofmac »
I can also throw in that this would also happen to me and it turned out to be a tear in my intake hose between the intake manifold and the airbox (basically air got in without being read by the MAF sensor (I think it's a maf on these cars? not a map?).
I ran to autocheck and bought some new hose and replaced it all and no problems.
This is just what worked for me, it's worth inspecting as it could be cheaper than needlessly replacing a fuel pump ;)
