ABS and TRAC light on following battery disconnect
Joey
I disconnected the negative cable on the battery on my 98 S70 to clean out the flame trap, (all that went well). Then when I reconnect and restart and drive the car the ABS and TRAC lights come on and stay on....?? Did I burn it up or does anyone have any insight on this one? Thanks much!
White850Turbo
- Year and Model:
http://home.earthlink.net/~vicrocha/
Probably just coincidental that it happened after battery disconnection. Very common problem in '96 and '97 850's and '98 S70's, as well as a few other models.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Joey
Well, here is an interesting resolution to my story. Just for fun, I stopped by Autozone and had them put the code reader on my S70. No error codes came up, but when I drove away the ABS and TRAC lights were off and stayed off even as I went past the 20mph point. I tried out the ABS with some hard braking and they work fine.... sheesh...! I think there are little electricial elves in the car!
- 631 Views
Last post by rspi
- 26 Replies
- 6688 Views
Last post by Roger_850T
