Best Start to Aftermarket Upgrades? Anyone?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
g4m3r89
Year and Model: S70 GLT 1998
Post by g4m3r89 »
I drive a 1998 S70 GLT and I want to start getting some aftermarket parts to boost the performance and overall look of my car. Any Ideas? Please help.
-G4m3r89
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Check out IPD's web site. It depends on how much you're willing to spend on this car, but you can do some pretty awesome things to it.
In particular, I can recommend the IPD HD turbo control valve. I put one in mine, and once the car re-learned everything, it feels like a rocket.
'98 S70 T5
2016 Chevy Cruze Premier
lienmarine
Year and Model: 1998 V70XC
Post by lienmarine »
The best start to adding performance parts is a good Stage 0. You can start putting aftermarket parts on, but usually they'll put more strain on the factory parts that have almost 15 years of use. Replacing plugs, wires, vacuum lines, PCV etc, first will make it better in the long run. Once you're happy with the Stage 0 that you're at, the IPD HD TCV is a great choice. The first mods I did after Stage 0 were K&N, IPD HD TCV, adjusted waste gate, CBV block off with Forge DP BOV, and IPD boost gauge kit. Overnight, it changed my XC from average wagon to snappy boosted monster.
1996 850 N/A 5 Speed 167k SOLD
1998 V70XC 153k
-Full Stage 0, HD End Links, K&N, IPD HD TCV, Forge DP BOV, shortened wastegate actuator, IPD boost gauge, Mobil 1 oil and bevel gear, 8000k HIDs, PIAA fogs.
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
as far as your cosmetic upgrades, what are you looking for is really the direction your going to go.
are you looking for classy volvo.
trying to spice it up but not go overboard?
remember you dont drive a car out of fast and furious so no underglow, unless you really wanna rock it. lol.
There is alot you can do, change the grille either with black plasti dip, or buying a new one from IPD or elsewhere.
spraying your corner lights orange.
lowering springs.
how far are you wanting to go. and remember, DIY and Junk Yards, are your friends when working with a volvo.
the dealership will drain your wallet fast.
zhenya
Year and Model: 97 855 T5,98 V70 AWD
Post by zhenya »
This Turbo Control Valve is only available for '98 cars and up, right, ie. not for the 850's?
lienmarine
IPD only sells it for the 98+ cars. Not sure about the turbo set up on the 850s, but I know the 98 S/V series is pretty darn close to the 97 and older cars. 99 was the big change with the ETM and what not, I'm not sure why the wouldn't work for the 850.
1998 V70XC 153k
lienmarine
Well, I got curious and found out why the HD TCV doesn't work on the 850s. S/V series cars have an electronic sensor that detects boost pressure and opens the wastegate accordingly. The 850s have a boost solonoid and no electrical connector to the boost valve. Sorry.
1998 V70XC 153k
RobTheModd
zhenya wrote:This Turbo Control Valve is only available for '98 cars and up, right, ie. not for the 850's?
Is this the same as the boost controll?
if so, then yes you can put one on a turbo 850.
zhenya
Post by zhenya »
lienmarine wrote:Well, I got curious and found out why the HD TCV doesn't work on the 850s. S/V series cars have an electronic sensor that detects boost pressure and opens the wastegate accordingly. The 850s have a boost solonoid and no electrical connector to the boost valve. Sorry.
Odd, because I found a post over at Volvospeed (don't have the link now) from Lucky at IPD when he was first releasing this product in summer of '08. Someone there asked the same question, and he said that it was just a matter of a minor change to make it work with the 850 and that he'd be releasing it soon. Obviously he hasn't, so...
zhenya
Post by zhenya »
Ok, so would this be the part that the 850's use? http://www.ipdusa.com/Volvo-850/Engine/ ... -173-5550/
