To-do lists for your Volvo this Spring?
Brazuca_ny
Year and Model: 2005 v50
Post by Brazuca_ny »
Its spring cleaning time for me TOO
installing angel eyes just arrived :::DONE:::
timing belt :::DONE:::
new grill :::DONE:::
New radiator, Cracked mount. :twisted:
new cooling lines
new rims, alignment
ac rebuild
the list seems to go on and on and on and on ..........
and to think I bought the car to save money, :mrgreen:
97 850R, 128000 RIP
96 850 R, 150000,flame red SOLD
2012 S60 t5 amber flame, beach wood interior, sexy baby ;)
2007 xc90 49000, Black on Black, family tank. :)
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
c_leforce wrote:vacuum hoses
expansion tank
top motor mount
door check
pads and rotors
start interducing new ATF into the old and hope it doesn't do in the tranny
pcv
oil/filter
fuel filter
cbv
timing kit <--- staying away from doing this myself
If you're doing all those other things yourself, the timing belt wont be a big deal.
1996 850 Turbo Wagon
atgunning
Year and Model: V70, 1999
Post by atgunning »
Man, my list is just getting longer:
Done:
Front rotors and pads
Rear rotors and pads
Left Lower control arm
Alignment
both front outer tie rod ends
Oil change
Tranny fluid drain and replace x 2
Cabin Filter
Intake Air Filter
Wipers
Fuel Filter
Serpentine Belt
Brake fluid flush with ATE Super Blue
Still to do:
Rear Shocks
Front Struts and Spring Seats
Tailgate Latch replacement
Front passenger door lock assembly
Drivers sun visor
Front end links - IPD Heavy Duty
Misc. interior and door courtesy bulbs
Interior detail
Patch the paint on the hood with OEM touchup
Spark Plugs
Rear washer fluid pump
Timing Belt
Water Pump
Thermostat
Upper Rear motor mount bushing
ABS Control Module - i think, although it could be the rear wheel speed sensors
Cup holder replacement
takane2
Year and Model: 850, 1997
Post by takane2 »
Here is my list as soon as the semester ends:
-sand/touch up paint chips on front end.
-clean off/repaint various scuff marks.
-seal windshield chips.
-realign tach and fuel gauge, reseat dash.
-Fix ABS issue.
-Fix A/C.
-Fix radio reception issue.
V70Johnson
Year and Model:
Post by V70Johnson »
Procrastinated due to lack of funds, recently completed (thanx to a generous tax return):
-timing belt & tensioner
-serpentine belt & tensioner
-water pump
-spring seats
-swaybar end links
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
Just buttoned-up the new blower fan, found I need a new power regulator, too - damn.
Installed new gas struts for the hatch - Super easy if you've been putting it off! Do it Do it Do it!
Also noticed that there's a huge crack in the windshield. Didn't see it 'cause it's right behind the rear-view mirror!
Just ordered:
The suspension and steering kit from Groton - I think the dead shocks may have something to do with that cracked window...
Air injection parts so I can pass emmisions test (what - It's only 5 months late . . . .)
Need to swap the timing belt soon - yeah, it's overdue.
For fun I'm going to paint the plastic parts under the hood bright red to match the car and paint the factory grill black - just not sure if it'll be glossy or flat, or if I should remove the stripe and emblem or leave 'em in place.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
c_leforce
Year and Model: 1997 850glt
Post by c_leforce »
expansion tank
top motor mount
door check
pads and rotors
pcv
oil/filter
fuel filter
cbv
Looked into it and found it not to difficult, its the first think im doing now...still its more nerveracking when its your own car
Brazuca_ny
TB, is not bad at all just make sure your marks are true, you shoul be fine, do it before it bites you in the ass. :mrgreen:
97 850R, 128000 RIP
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I was thinking about this today as I am putting together a parts order.
The '94 N/A
Replace front motor mount.
Replace right side axle.
Replace tie rod ends.
Replace shocks and struts - I might as well deal with the spring seats while I am there.
I just replaced the clutch and the seals for the axles and the rear main even though they weren't leaking as PM.
The '96 Platinum
Alternator - the instrument cluster is lit up like a Christmas tree - Tomorrow.
Oil Change - Tomorrow.
Pending - I may need to yank the dash again as it seems I have a slow freon leak. :cry:
The '96 N/A
Brake pads - his (my son's) are the newest in the fleet but he thinks he needs to change them - I think I will chekc that before I buy the parts.
Rear Shocks
Get the proper anaerobic sealant and finally end the oil leak between the block and the sump pan.
Oil Change
