service light takes 5 mins to go out 855 T-5 RHD auto
Does the service light on the 850 T-5 series take a while to go out ? Mine can take 5 mins before it will go out then other times it goes out instantly
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
It's supposed to take 2 minutes. On a 97 or 98, it can't be reset except by a special tool or the dealer scan tool.
I took my bulb out when I changed the dash bulbs and smashed it. Stupid annoying piece of junk
'98 S70 T5
2016 Chevy Cruze Premier
IgotaLemon
- Year and Model: S70 1998
I believe it is a standard feature on all volvo's to have the service light come on after so many miles. There is a posting which refers to reseting the service light so it will not come on anymore. maybe you should look for that posting, good luck.
I'll take a look it does go out eventually tomorrow I will time how long it takes to go out so if its within the alloted time then thats ok and I will look up how to reset it once and for all
- Year and Model: Many Volvos
- Been thanked: 76 times
The way I do that is to remove the lamp, throw it down the street, and then go stomp on it until it is in pieces to make sure it can never come back.reset it once and for all
lienmarine
- Year and Model: 1998 V70XC
I think it's any of the OBD II Volvos that need the special dealer reset. My 96 needed it. I just swing by the dealer and have them reset it for free. Problem solved for 5000 more miles.
1996 850 N/A 5 Speed 167k SOLD
1998 V70XC 153k
-Full Stage 0, HD End Links, K&N, IPD HD TCV, Forge DP BOV, shortened wastegate actuator, IPD boost gauge, Mobil 1 oil and bevel gear, 8000k HIDs, PIAA fogs.
1998 V70XC 153k
jblackburn
LOL I'm glad to see someone else enjoyed smashing itOzark Lee wrote:The way I do that is to remove the lamp, throw it down the street, and then go stomp on it until it is in pieces to make sure it can never come back.
'98 S70 T5
