headlight & window washers
2005 Volvo XC70 - headlight washers work but windshield and rear window washer do not work. I think there are two pumps but not sure where they are located or which nozzles they regulate. Considering my problem I'm assuming that there is one pump for the headlight washers and another for the windshield and rear window. Does anyone know if this is correct and where the windshield pump is located and how to access it?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
It might be a pump, and it might not.
I recently blew a hole in a T-valve that controlled all of mine.
Get someone to tug on the wiper stick while you look around under the hood for fluid spraying out everywhere. Mine was located here:
'98 S70 T5
2016 Chevy Cruze Premier
