960 trans service
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
hollywood953
Year and Model: 960 1996
960 trans service
Post by hollywood953 »
I pulled the trans dipstick and the fluid smelled very burnt. I followed the steps for just draining the fluid (3.5 quarts) and refilling with new fluid. I plan to drop the pan and clean the screen and change the filter this weekend. I checked the fluid cold today and it look like it's WAY too full. Is there a trick to doing this? I haven't run the car in a few days due to this misfire thing. I used a ratchet to get it out from the top.
ps.. you guys (especially Bill and JD) are awesome. I am giving to support and buy from you links. IF ANYONE ELSE OUT THERE SAVES MONEY USING THIS SITE GIVE BACK TO KEEP IT UP. These guys could charge for their help.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The cold fill mark is almost always off.
Drive around for 10-15 minutes, and then check the level at the HOT mark with the transmission in park and the engine idling.
You may want to do another drain and fill in a few days to push more of that old nasty fluid out of there. When I flushed mine, the fluid was nearly black.
'98 S70 T5
2016 Chevy Cruze Premier
hollywood953
should I drop the pan and clean the screen? The instructions on this site say to disconnect the hose and run the engine until new fluid comes out. should i do that? The manual says this car holds 7.5 quarts of fluid. I guess the trans cooler holds about 4 quarts?
jblackburn
I wouldn't worry about the screen for now. Generally if that is clogged up, it's starving your pump and the transmission is already not working anyway.
I wouldn't do a full flush on it just yet. I would do another 2 or 3 drain-and-fills for now, space them out 2 or so weeks between each. After your fluid is red-ish, and after it's been run through it for a few months, I would say it's safe to "graduate" to the full flush. The AW transmissions are a bit sensitive to being flushed if they're older and by replacing ALL of the old fluid at once, you may just cause more problems with it by removing all the gunk held up on the internal components that it has gotten used to.
Hopefully that makes sense, I think I'm kinda failing at explaining :mrgreen:
'98 S70 T5
hollywood953
I agree, I will drain and flush after a couple of weeks. It makes sense to me that if I took out 3.6 quarts and put back 3.6 quarts and there is no leak it should be ok?
jblackburn
Sounds about right. Unless it was overfilled in the first place. Like I said, the cold mark is almost always off - you did the right thing by measuring it and refilling.
'98 S70 T5
hollywood953
thanks, I will check it warm tomorrow.
