Is there an antennae delete kit for an 850 series?
Michelle
Year and Model:
Post by Michelle »
Yes, I broke mine and I'm pretty sure I'll do it again :oops:
kelvin6
Year and Model:
Post by kelvin6 »
If you remove the antenna, then you have to figure out a way to plug up the hole. My suggestion is to (if you can) lower the antenna all the way down and then remove the power connector at the power antenna motor (should be a square/rectangular connector). Thats what I would suggest.
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
Guest
Post by Guest »
"...If you remove the antenna, then you have to figure out a way to plug up the hole."
Little piece of duct tape?
"Yes, I broke mine and I'm pretty sure I'll do it again"
Not sure what you are saying, but your statement is mysteriously provocative to me. *needs to go take a long walk in the park*
