S70 Ambient Temperature Sensor Fix
Gazoogleheimer
Year and Model: 1998 S70
Post by Gazoogleheimer »
An interesting fix for a bothersome problem some of you might experience. Even though I've figured it out, I think it might be of help to some of you at some point (Or not, oh well.)
Regardless, the temperature shown in the trip computer area on my dash was consistently about 20-30 degrees F higher than ambient, especially after a drive (Atlanta's hot, but not 130 degrees!) I kept trying to find the temperature sensor--and discovered that was my problem.
Turns out the temperature sensor that fits into the driver's side lower grey plastic cowling on the bumper can pop out and fall into a metal tray under the engine compartment--not receiving the proper airflow it requires for an anywhere near reasonable reading.
After popping off the cover, I fished around with my hand and found the little sensor which clipped back into the plastic hole. Now the temperature reads correctly (at least while the car is in motion and it has airflow.)
A picture of the sensor in place:
moondust
Year and Model: 2000 S70
Post by moondust »
I am having very similar problems with my 2000 S70 but I cannot locate the temperature sensor.
Is yours the same model? You had a picture posted but I do not see it on the post.
I would appreciate pointers and pictures, if available, to help me locate the sensor.
Thanks
