I HAVE A CODE P0785 SHIFT / TIMMING SOL MALFUNSION
TELL ME LOCATION AND HOW TO CHANGE IT
Transmission codes on 2001 V70
Reason: Edited title for clarity.
- Has thanked: 2660 times
- Been thanked: 1255 times
Peter, please type in normal case... capitalize the first letter of the first word of a sentence, and proper nouns. The rest leave lowercase.
The forum rules are a good thing to read, like you agreed to when you registered.
We'll need some background. We're usually better at helping if you tell us what happened to your Volvo: when the fault occurred, what you've done, symptoms, recent work, past maintenance history, mileage and other related info, instead of just a code.
SORRY MY NAME IS pETER mATHEWS I AM A CAR DEALER I JUST GOT THIS CAR TRANSMITION PROBLEM CHEANGE OIL (FLUSH TRANSMITION 3 TIMES . GOOD OIL NOW CHANGE 2 MOTOR MOUNTS . NOW LOTS OF THE PROBLEMS ARE FIX . oNLY PROBLEM LEFT IS SHIFTING PROBLEMS A LOT BETTER THAN BEFORE . I GOT 2 CODES P0785 AND P1618
JRL
- Year and Model: Several
- Been thanked: 16 times
This is how you type, NOT LIKE THIS! Turn off the CAP lockPETER56 wrote:SORRY MY NAME IS pETER mATHEWS I AM A CAR DEALER I JUST GOT THIS CAR TRANSMITION PROBLEM CHEANGE OIL (FLUSH TRANSMITION 3 TIMES . GOOD OIL NOW CHANGE 2 MOTOR MOUNTS . NOW LOTS OF THE PROBLEMS ARE FIX . oNLY PROBLEM LEFT IS SHIFTING PROBLEMS A LOT BETTER THAN BEFORE . I GOT 2 CODES P0785 AND P1618
Unfortunately this is an 01, known for bad transmissions. You did not state the mileage but an internal fault like this is usually terminal.
You probably will need a new (or used) transmission. (which is how it is spelled)
