i made the mistake a while back of trying to remove sap from my car with the green side of a sponge, later finding bug and tar remover it came off in seconds with no elbow grease at all. im now left with some blemishes on my hood and rear quarter panel. ive tried polish and then hard shell wax, these take out all of them until the first heavy or for that matter any rain.
the rain takes the wax right back off and leaves me with the marks again. is there a better way to take these out?
Paint Scratches That Wont stay away
volvomileage
- Year and Model:
meguiars scratch x easy instructions and user friendly it even removed light water sand scratches there is even a tutorial on youtube, i would use some wax remover or a clay bar prior to using this product in order to get a clean surface to get best results
best of luck
best of luck
volvo 850 95 sedan non/turbo 185 k
You might need an orbital buffer and some light compound. It is hard to take out scuffs like that with just elbow grease. The orbital buffer can be bought anywhere for about $40-60 and of course you can use it to apply polish and wax.
The polish isn't going to cut enough and the wax will just cover it until it wears away.
do you know where this is available?volvomileage wrote:meguiars scratch x easy instructions and user friendly it even removed light water sand scratches there is even a tutorial on youtube, i would use some wax remover or a clay bar prior to using this product in order to get a clean surface to get best results
best of luck
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
volvomileage
- Year and Model:
i guess pretty much everywhere where waxes and car polishes are avail, if not meguiars sells it on their ws
http://www.meguiarsdirect.com/product_d ... MEG+G10307
btw using an orbital is a plus
twoeyesopen
- Year and Model: 1998 S70
Don't be surprised if off the shelf scratch removers are not aggressive enough to smooth out the scratches. Those green pads can cut pretty deep into paint. You may have to go to a medium cut or heavy cut compound. (also available from meguiar). A good deal of caution should be exercised when using one of these more aggressive compounds and an orbital may not be enough to smooth out the scratches they put in. If the Scratch X doesn't do the job a good body or detail shop with a high speed buffer and a good detail man can do an entire hood in about an hour. Absolute best procedure is wet sand with 1200 grit, then 1500 grit, then 2000 grit, then 4000 grit, then buff. Then you will have some really smooth spots. These compounds have oil and wax in them so tell the shop beforehand that you will ask to see the areas be wiped down with a cleaning solvent. You want to check the work with no wax or oil to make sure the scratches are gone. If they don't want to do that go to another shop.
volvomileage
- Year and Model:
agreed an absolute clean area free of wax and other residue is the best way to start especialy prior to colour sanding
if scratches and blemishes are light scratch x should do the work otherwise a good compound and in more severe cases colour sand
MilehighV70XC
- Year and Model: '99 V70XC, 143,000mi
You will probably need to do several steps if the scratches are more then 1500 grit deep. When I got my car it had never been detailed. I had to start with meguiars medium cut, then megs fine cut, then 3m polish, then megs NXT sealer, then S100 carnauba wax. It was a lot of work but well worth the time. This was done with a Porter cable orbital buffer.
BEFORE
MEGUIRES MEDUIM CUT
MEDUIM CUT --LEFT MEGUIRES FINE-CUT --RIGHT
3M PERFECT II POLISH
MEGUIRES NXT TECH WAX 2.0
BEFORE
MEGUIRES MEDUIM CUT
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
Good job, great pics. Thanks.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
hahaha holy s hit thats a big difference i need a orbital i did the scratch remover and then the good wax u mention above in it and most came out however the medium cut stuff is needed next. ill take pictures tomorrow.
1999 v70R 126,000
1999 v70R 126,000
