My 855 won't start.
Put in the key and turn and it doesn't crank.
Christmas tree on the dashboard.
Fuel pump active.
Sometimes I'll get a click like a relay and sometimes not.
I've seen a number of references to a "starter relay" but no instructions on where it is.
Help?!
Starter relay?
- Year and Model: Many Volvos
- Been thanked: 76 times
Chances are you have a failing PNP switch. Try rowing the shifter back and forth from low to park, quickly, about 20 times and then see if the car will crank.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Bad camshaft position sensors? Or ECT? Usually those two sometimes cause the no-crank problem.
Are there any codes that you can get?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
FlyingVolvo
Sorry, the engine coolant temperature (ECT) sensor will sometimes not allow the engine to start if it's faulty, although I think usually it will still allow it to crank.
Pretty certain though that the cam position sensor will not allow cranking.
2023 V60 T8 PE
2023 V60 T8 PE
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I vote for the cam position sensor.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
oldschoolvolvo
- Year and Model: 1979 242DL
I'm going to resurrect this thread b/c I have the same intermittent issue as the OP. Happened this morning where turned the key, everything lights up as normal, fuel pump on but no crank. I held the key in the "start" pos for ~20sec before the car turned over and started. PNP has been replaced in the last 2yrs, cam sensor replaced a few months ago, no CEL codes. My gut feeling is there is a sluggish relay somewhere. Any thoughts?
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
- Been thanked: 504 times
The 1998 S/V70 has starter relay (previous years 1994-97 has no starter relay).
To test the starter motor, remove the Starter Relay, use a jumper wire and jump 30 and 87, the starter motor should run, if not the problem is in the wiring or starter motor itself.
I made a diagram here for all the fuses/relays for the 1998 S/V70:
oldschoolvolvo
awesome! thank you!
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
- 1333 Views
Last post by BEJinFbk
- 769 Views
Last post by ggleavitt
- 1763 Views
- 4387 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
