What is this?
patrickjcrum
Year and Model:
What is this?
Post by patrickjcrum »
1995 850Turbo, 143000 miles or so.
Can anyone tell me what this is? it looks like it's part of a sensor that may have broken off? I'm pretty sure it's part of the AC.
Thanks in advance!
Pat
JDS60R
Been thanked: 3 times
Post by JDS60R »
Looks like someone replaced part 20 with something
See attached.
1995 850 turbo ac components.pdf
(174.35 KiB) Downloaded 220 times
Retired
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
It looks like it might be part 44 or 45 with half of it broken off to me.
petek153
Year and Model: 1992 940T
Post by petek153 »
pressure switch for AC FCP 1995-1997 Volvo 850 A/C Pressure Switch
http://www.fcpgroton.com/product-exec/p ... gory_id/66
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
JDS60R
Post by JDS60R »
I agree = looks like the pressure switch for the win
Retired
patrickjcrum
Year and Model:
petek153 wrote:pressure switch for AC FCP 1995-1997 Volvo 850 A/C Pressure Switch
OK, Thanks! What does it do? if I put off replacing it what problems can I expect?
Cheers,
Pat
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
basically its a safety feature if your a/c sys. pressure get to low or high it will shut the a/c compressor off.
1996 Platinum Edition
Retired MVS Contributor
Post by Retired MVS Contributor »
It is the high pressure cut-off...The low pressure cut-off is near the firewall on the larger of the two A/C lines that go through the firewall...Thin line, high pressure...Thick line, low pressure...It is important because you have to order the right swich...
There must be an electrical connector swinging in the breeze somewhere in there...It will have the rest of that broken switch...I believe that switch is called a pressostat...
patrickjcrum
Year and Model:
jerrymcc wrote:There must be an electrical connector swinging in the breeze somewhere in there...It will have the rest of that broken switch...I believe that switch is called a pressostat...
it's in the foreground of the 2nd pic, plugged into a dummy port (why it's there I have no clue!) I just put it there back when I changed my belt and noticed the switch was gone to avoid it just dangling loose.
Near as I can tell, It hasn't been there in a long time.
