chassis settings
tmjohnson
Year and Model: s60r 2004
chassis settings
Post by tmjohnson »
I have an 04 s60r. replaced the upper strut tower boot. Now when turn wheels as sharpe as you can and drive, the little text window says active chassis service requried. only does it when you turn wheels real sharpe. what do i need to to fix, besides take it to the dumb dealer. my luck thats where it will have to go.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
The odds are a shock (4C) connector either is loose or came off.
Check the shock(s) you worked on, I'll bet a connector is not snapped all the way in or a wire is broken
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I had this issue on my 04 S60R when the alignment was way off. Did you have the alignment checked out after you replaced the spring seat? If not, you really should.
