chassis settings
chassis settings
I have an 04 s60r. replaced the upper strut tower boot. Now when turn wheels as sharpe as you can and drive, the little text window says active chassis service requried. only does it when you turn wheels real sharpe. what do i need to to fix, besides take it to the dumb dealer. my luck thats where it will have to go.
JRL
- Year and Model: Several
- Been thanked: 16 times
The odds are a shock (4C) connector either is loose or came off.
Check the shock(s) you worked on, I'll bet a connector is not snapped all the way in or a wire is broken
- 705 Views
Last post by goldmandan
- 1293 Views
Last post by Georgeandkira
