Actually, you can...What is meant by that opinion is that one can is probably not enough to overcgarge it, but it really is, and follks often heat it to get more in...There is a definite realationship between pressure and temperature with refrigerants, that's why they work the way they do...50 pounds means it is undercharged and it will not produce optimum cooling...The evaporator temperature is only 47 degrees at 50 pounds...Optimum sooling will occur when the evaporator temperature is 32 degrees and that works out to about 30 PSI...As more refigerant is added to a low system, the pressure goes down, not up, because we are reading the compressor's SUCTION pressure, not system pressure...Optimum suction pressure is 30 PSI...geokilla wrote:Actually, you can go over 30 PSI from what I read. It's just that the AC performs best at around 30 PSI. Mine was charged to 50 PSI by the "Volvo specialist". Well unless we checked it wrong, it's at 50 PSI.
And from what I heard, you can't overcharge if you're charging it from a can.
Visit airconditioner.com for very comprehensive info on how A/C works and how to service it...Here is a starting quote from that site...
Basic Charging Procedures
REFRIGERANT CHARGING PROCEDURE IN AUTOMOTIVE A/C SYSTEMS
We recommend reading this procedure completely before charging. You may need information before charging you want to keep handy. Have this procedure with you while charging. Although it can be done by a single person, we recommend having a helper around.
This procedure outlines the steps to perform a complete charge. These steps are not to be used to refill or make partial charges. Toping off requires system parameters monitoring and knowledge, specially in R134a-based system. Excessive gas will harm your system and will keep it from cooling properly. MORE REFRIGERANT DOES NOT MEAN COLDER TEMPERATURES
