I changed out my odometer gear and I thought everything went great. However, it has been several days since the repair and this morning was the first time that I had driven it in the dark. The LCD information center works, but it does not light up when the lights are on. Before I tear out the cluster again, can someone tell me what I need to look for. I don't recall any light connector for the LCD info center.
Thanks,
Bobby
Problem after odometer gear repair Topic is solved
- Has thanked: 2662 times
- Been thanked: 1256 times
Look for the bulbs to be properly seated. One of the two in my 850 loses contact from time to time and a smack on the cluster panel in front of it reminds it to light up.
- dosbricks
- Been thanked: 2 times
The elements in the bulbs seem to get fragile with age. The jostling they get when the cluster is removed can cause them to fail. On advice from a VS thread, I replaced mine when I did my 850 gear.
However....Look at it this way. You saved about $400 over the cost of a dealer repair.
newguy
Regarding the replacement gear for the odometer -- where did you locate the new gear?
I am in the same bind and would like to save myself the $$ and fix it myself.
Thanks,
Marc
Thanks,
Marc
greeselightning
- Year and Model:
Here is one website you may want to look into. There maybe others but this is the only one I have seen so far mentioned in Volvo forums I've joined.
http://www.odometergears.com/
Dosbrick - where did you get the lightbulbs? Are they available at your local auto parts shop or did you get them via the web.
- dosbricks
I bought them from the dealer. There are 4 larger bulbs for the instruments and 2 smaller ones for the LCD clock/temp. They cost $12 for all.greeselightning wrote:
IPD has a kit but it includes a DVD how-to for cluster removal and costs $29.95. Volvospeed.com has the how-to for free.
- dosbricks
https://www.matthewsvolvosite.com/chat/p ... meter+gearwalker wrote:I have a new gear for the odometer, but I am unsure where it sits. Does it just sit inside the larger gear loose? Help?
guest
Hey, thanks for the information! I bought a gear from the site you mentioned and fixed it myself in about 1.5 hours (while watching t.v. mind you) no issues.
Thanks!!
Thanks!!
