P1171 code 01 V70 2.4t
whaleplane
Year and Model: 2014 S60 T5
Post by whaleplane »
I went to my local volvo guy for an oil change and in the process he also checked the code that is causing the CEL to come on. It came out P1171. He metioned something about a sensor that is checking the fuel air mix. Well, he cleared the code and it stayed off for most of the day but it has come back on. Is there a larger problem with this code?
Thanks.
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
Have you cleaned your MAF sensor? One of the easiest and cheapest eliminations of your problem...this code tells you that something is not right with your fuel air mixture. Not saying that this will fix the problem, but a step in the right direction.
https://www.matthewsvolvosite.com/forums ... 81#p121281
Jan
Former 2001 V70 2.4T owner
whaleplane
I have not..yet. That will be on my list tomorrow. Thanks for the link.
