Good night gents!
I have the ABS light turned on shortly after after start running. Is a 1995 Volvo 850 GLT Non turbo.
Last week cleaned all wheel sensor and put new ones on the Front Wheel but codes keep coming.
How to clean ABS codes?
Also I read somewhere here that could be bad Wheel Sensor Reluctant Rings, does anybody knows where they go and how to clean them and also if they are bad how much can cost each and where to buy ?
Thank you,
Southern80
ABS light 1995 Vovlo 850 GLT non Turbo
On some models pre 1996 you can access the codes from two boxes next to the screen filler marked "A & B" if your car has these two boxes here are the necessary codes if not then you will need to get an OBDII Scanner
https://www.matthewsvolvosite.com/volvo- ... ble-codes/
As for buying a new sensor FCP Groton or your local Volvo agent will be able to give you the best price as they're around £50 here in the UK
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
- 941 Views
Last post by SuperHerman
- 427 Views
Last post by vtl
- 10 Replies
- 2103 Views
Last post by lcc014
- 10 Replies
- 6156 Views
Last post by misha
- 1821 Views
Last post by viper69
