Someone has just posted the best head gasket replacement tutorial I have ever seen on another forum.
Volvo 5-cylinder: How to Replace the Head Gasket
Excellent head gasket replacement tutorial
S60 Front End Clunking
C@lvin
- Year and Model:
- Been thanked: 2 times
No, it's not against the rules. Matt wants stuff to be here, but if not, he wants MVS to be the place where people can find the links to it if they do happen to be somewhere else. Unlike some sites, there is no problem with referencing other places where useful information can be found.
Also......that is as you said an excellent tutorial. That guy did extremely good work. I appreciate your showing it to us.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Not against any rules at all, and thanks for posting this! This is going straight in the repair database
'98 S70 T5
2016 Chevy Cruze Premier
wheelsup
- Year and Model:
- Has thanked: 15 times
- Been thanked: 20 times
I printed all the pages (9 html pages) and that converted to about 70 pages in PDF format. In case that site ever goes down, we have it here on the MVS server in PDF format.
It's easier to view via the link above, but I just get worried that some of these things will be lost forever. Hopefully this isn't against the rules either?
1996 Volvo 850 NA Head gasket repair step-by-step
1995 850 GLT Wagon w/ 200,000 miles
- Year and Model: Many Volvos
- Been thanked: 75 times
All the same. The part numbers on your valves are different on the LPT versions but otherwise they all bolt up the same way.laddot wrote:I am new here and am planning a head gasket change/ head milling and valve job. Is this tutorial good for a 97 850 GLT model also?
I'm on FPC Groton's site ordering the parts from the list in the tutorial, and then I saw a "head gasket set" listed. Only problem w/it is it doesn't list out the contents of the kit. I does say to order the bolts, water pipe gasket and thermostat housing gasket. Has anyone used this kit who can say if it has everything else neede for a HG job?
Thanks
Thanks
Scooter7, the pic shows the following parts in that kit:
Head gasket
Exhaust gaskets
Intake gasket
Valve stem seals
Oil pump gasket, O-ring, and seal
Cam seals front and rear
Crank seal front and rear
Spark plug O-rings
Thanks for all the kind comments about my tutorial. Putting the tutorial together took as long as the repair, but I knew it would be worth it.
Tracy
Head gasket
Exhaust gaskets
Intake gasket
Valve stem seals
Spark plug O-rings
Tracy
Tracy
So I've been finally able to get to working on my car. I made it to the step where I have to use a puller tool to take off the camshaft pulley. Everything is lined up and I am using the puller and by tightening it the whole pulley moves clockwise and the pulley also has come half way off.( I read that nothing was supposed to move or else it would mess up my timing.) Should I try and tap the pulley back on to be able to turn back the camshaft to its original position or is there something I can do later to fix the problem later....??
