s701998 po172 119,000
tmower
Year and Model:
Post by tmower »
1998 s70 replacement engine with 119,000 miles. Consistently reading code po172. To those of you who may be familiar with this, do you any suggestions? I appreciate your input.
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I am trying to find that code but I am having a hard time. When you scanned the computer and that code came up, did the reader give you a description of what the code meant?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Post by jblackburn »
Most often, this code is caused by a vacuum leak. Look at all hoses into the intake manifold - starting with the one connecting into the passenger side of the manifold.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
If it is that one, space in there's real tight. This is how I went about fixing it.
'98 S70 T5
tmower
Year and Model:
Post by tmower »
Yes. The description reads Sys Too Rich, Bank 1. Had gasket leak repaired, but code consistent. Any idea?? Thanks!!
tmower
Year and Model:
Post by tmower »
PO172 READS SYS TOO RICH, BANK 1 -- STILL A VACUUM HOSE?
jblackburn
That's the most likely scenario.
'98 S70 T5
tmower
Year and Model:
Post by tmower »
Will ask to take a closer look at the vacuum hoses, although mechanic says he already checked. Any other possibles?
And, most importantly, is this causing damage and/or is the car safe to drive?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
99 times out of 100 it is the vacuum elbow from the PCV at the US passenger's side of the intake manifold that was shown previously.
It is a pure SOB to get to due to limited access so as to make the repair since it is crammed in so close to the alternator.
Long story short it should be a cheap repair that is a bit of a pr!ck to get to.
tmower
Year and Model:
Post by tmower »
Will take a closer look. Thanks so much for your advice on this one...
