My volvo can start, but it begins to stall out and then quit (less than 30 seconds). I have replaced the fuel filter and the fuel controller fuse under the fuse box. The car will not even turn over to start after about 3 or 4 attempts at getting it to continue running.
What other problem areas should I check.
Joey PIttman
keeping my volvo running
How to Flush Volvo Power Steering Pump
Guest
How old is your battery?
4 years or more and it could be too weak. Earlier this year, I had similar symptoms with my '96 850. I knew the battery was a little over 5 years old. Replaced it that afternoon and the trouble went away.
White850Turbo
- Year and Model:
what year car? got any codes?
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
- 469 Views
Last post by neworleans
- 379 Views
Last post by stephonis01
