Drivers door master window switch
This topic is in the MVS Volvo Repair Database » VADIS: Diagnose and Repair Your Volvo
anbran
Year and Model:
Post by anbran »
How do I remove the power window master switch (on the driver's door panel) and replace it?
1999 V70
Thx
1998 V70
Near Guelph, Ontario, Canada
jbo6924
Year and Model: 1998 v70 t5
Post by jbo6924 »
you can use a wide blade screw driver (I covered the blade w/blue painters tape to limit any surface damage) and slip in under the front of the retention trim ring that surrounds the actual switch and GENTLY pry it up. It worked for me! Good Luck!
Jim
anbran
Year and Model:
Post by anbran »
This is while the door panel is still attached I expect?! The Haynes manual suggests I remove the entire panel?!
Oh ya...Where is the "retention trim ring" you refer to?
Thanks again
1998 V70
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
The outside trim (plastic surround ring)
Pry hard and up, be careful of the leather
NO ONE removes the door panle
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The cheapest replacement I have found is at www.Tascaparts.com . Around $104.00 + freight for the OEM replacement. It just pops out of the door panel like previously described. Everyone else seems to think it is worth $135.00.
pablotar
Year and Model: v70 1998
Post by pablotar »
Yeah, what everybody else said.
For what it's worth, I took my switch apart and cleaned out the fuzz and grime from the contacts and it works great. If you're mechanically inclined it isn't hard and it's been fine for over 2 years now.
1998 volvo v70 non-turbo 140,000
I go to the junkyard to practice future repairs.
