Transmission or Electric ?
Volvo Synthetic Oil Switch with High Miles?
new volvo 850 guy
saltydog
I had a 96 845 with the same problem - I assume that you have a flashing orange arrow on the dash & on your pwr/econ switch on the console. There is a selenoid inside the tranny. most dealers will tell you that it's non-servicable & you require a re-build, but find a tech who knows the tricks, & he should know what to do. It's not an unheard of problem. I think the part was around $140.00, but you do have to split the drivetrain to access it.
guest
Has anyone else had this problem? Cause I found out I have the same problem. Does anyone have more information how to get it repaired? Sounds like a long labor. What is selenoid??
Guest
Mine just started doin that for no reason last week. When it does go it will get stuck in 3rd gear and will not upshift or downshift.
- Has thanked: 2664 times
- Been thanked: 1256 times
Flashing up arrow on dash?
Are those people who are just experiencing this living in cold regions? Mine did it once when I left it at the airport last winter, it is normally in a heated garage. I didn't do anything to the car except let it warm up for a few minutes before taking off if it is left outside. Mine seemed like the torque converter was draining out while parked and then took awhile to get the ATF back around the trans. It very well could have been a solenoid though.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
