Hi there! I was going to work on this, but I see you recommend Dexron VI, but my owners manual recommends Dexron IIIG and so this website: volvospeed.com/Repair/s80_transmission.html.boosted5cyl wrote:Top it off with approx 7qts of Dexron VI when you are done. I've been pleased with Dexron VI in both the T5 (Aisin Warner AW50 tranny) and the GM 4T65E-GT in the T6. In my case I have done drain and fills only, no flushes. You can use the filter for 2000 Chevy Impala 3800, same filter but if you ask for the filter for your S80, it will probably be twice as much if not more![]()
I did a search and the found my transmission should be the AW 50-42LE. Is this right? Which fluid should I use?
