2000 S80 Temp. Gauge overheating
mikes S80
Year and Model: S80, 2000
Post by mikes S80 »
I just replaced my bad radiator and started it up. It ideled and heated up normally. I then test drove it, and after 1/4 mile it heated rapidly. I had the cabin heat cranked up, but it was blowing out cool air. I shut the car down to prevent overheating and opened the hood. The cooling fan was running normally. I thought at first maybe the thermostat, but it should blow hot air in the cabin if the motor is getting hot. I am confused. Any thoughts?????
Mike
AuroraTear
Year and Model: 1999 volvo s80 T6
Post by AuroraTear »
My 99 had a blown headgasket. Are you getting low on water? and look under the car toward the back of the engine and see if you see water dripping outta the back. white smoke from the exhuast, or water in your oil. when you take the cap off of your overfill tank does it fill up rapidly and boil over? All of those are signs you could have a bad head gasket.... Good luck it cost me 2800.00 and change to hve mine replaced.
On that note this car has broken me finacially and i wanna use it to go target shooting
jbrown122
Year and Model: 1999 V70, 1995 850
Post by jbrown122 »
You could easily have an air pocket inside the cooling system somewhere. Take the overflow tank cap off (green) and let the engine idle. After some time, you should hear a 'burp'. And that might help.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
+1.
Also have heat set on max and massage the hoses to and from the radiator.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
