I'm right in the middle of replacing the driver's side half shaft (axel). Everything came apart exactly as the instructions said. Now I'm putting the shaft back into the transmission, and it won't go! I can feel the splines line up but it won't go in all the way. I've lightly tapped on it when I had it straight, but still no go. So what's the trick?
While I have new lower ball joints I was going to put in while I was in here (doing the lower A arm as well), I can't get the old one out (the A arm is removed, and so are the 2 12mm head bolts). I've tapped on this with a drift and again no go.
Thanks for the help, I'll try the archives, but I had looked pretty extensive before I started, and didn't see any thing on problems getting this back together. You may see my post on the other forums as well.
Jerry
Need Help fast on half shaft install (axel)
Checksix
- Year and Model: V70 T5 2001
- Been thanked: 2 times
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
Checksix
Yep that's it, I wasn't doing it forceful enough. Backed it out a little and got a "running start", did the trick! Thanks JDA!!!
Jerry
Jerry
- 4705 Views
Last post by SuperHerman
- 1573 Views
Last post by Seaway
