Need Help fast on half shaft install (axel)
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Checksix
Year and Model: V70 T5 2001
Been thanked: 2 times
Post by Checksix »
I'm right in the middle of replacing the driver's side half shaft (axel). Everything came apart exactly as the instructions said. Now I'm putting the shaft back into the transmission, and it won't go! I can feel the splines line up but it won't go in all the way. I've lightly tapped on it when I had it straight, but still no go. So what's the trick?
While I have new lower ball joints I was going to put in while I was in here (doing the lower A arm as well), I can't get the old one out (the A arm is removed, and so are the 2 12mm head bolts). I've tapped on this with a drift and again no go.
Thanks for the help, I'll try the archives, but I had looked pretty extensive before I started, and didn't see any thing on problems getting this back together. You may see my post on the other forums as well.
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
give it a little force when you push it in. it feels like a click when it catches
Checksix
Post by Checksix »
Yep that's it, I wasn't doing it forceful enough. Backed it out a little and got a "running start", did the trick! Thanks JDA!!!
Jerry
