interchangeable wheels?
Sadenah
Year and Model:
Post by Sadenah »
Greetings,
Could anyone tell me if wheels from a:
1992 Volvo 960 - 5 lug pattern
will fit on my:
2000 standard V70 wagon.
195 65R 15
I am looking for wheels to place studded tires on.
Thank you
SUPERBRIK
Year and Model: 65&68 122 sedan&wago
Post by SUPERBRIK »
anmartin44
Year and Model: 1994 850 n/a
Has thanked: 2 times
Post by anmartin44 »
The lug pattern is the same but you might have some trouble with the offset. i think the rear-wheel drive volvos have something like 20 mm offset, while the fwd have around 40-43 mm offset. you may need wheel spacers for rwd wheels.
I think all fwd will fit your 2000 with the exception of 1993 850s. some ford wheels will also fit.
good luck
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
jimmy57
Been thanked: 320 times
Post by jimmy57 »
the 95-98 960/s90/v90 share the same offset but the 760/91-94 960 have the traditional offset of the rear drive models and will push your tires out too close to wheel openings. Contact will occur in rear on bumps and up front on bumps and probably at normal ride height when wheels are turned very far from center.
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
This is wrong.
Ambitious but rubbish
