P0444- Emissions Purge Valve
luckyirish7
- Year and Model: 850 R, 1996
I have gone down from 9 to 1 codes! Thanks Everyone. Now my last code is P0444- Emissions Purge Valve. I am not having much luck finding information on this. Can someone help tell me what I have to do to fix this. Thanks!
Ive had similar problems with low and no flow through that switch, i still do but just dont have the patience or for that matter a smoke machine to chase down the leak.
however if your valve is no good then you'll likely need a replacement, which i just happen to have one in front of me right now!
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Take your valve off and attempt to blow through it. You should not be able to unless the valve is no longer shutting like it's supposed to.
'98 S70 T5
2016 Chevy Cruze Premier
luckyirish7
I wont have time to look at it until Sunday at the earliest but would this be causing a slight hesitation in acceleration? It goes fine most of the time but every once in a while it hesitates at around 15mph around turns? Thanks
jblackburn
Yes, it will flood the intake with gasoline fumes and/or air if there's a leak elsewhere. The valve is set to open at higher engine speeds to allow it to burn off the vapors from the gas tank.
'98 S70 T5
luckyirish7
Thanks for the quick answer. Also i have found the part on line but does any have a link or picture or something to help me on the removal process of the emission purge valve?
jblackburn
It's on the radiator shroud. Pull off the plug and two hoses, pull off the valve, and attach the new one in the same orientation.
Ignore the blue arrows here; I took my picture from something else
'98 S70 T5
luckyirish7
If I used the wrong purge valve from my car what would it do? I actually put in the 94 none turbo... took a little shaving from the EPV itself to fit into the connection. But it looked like the same exact part otherwise. When I put it in and reset codes the PO444 code never came up again. IS it possible that the code is fixed but the car is still running like crap? Thanks
- Year and Model: Many Volvos
- Been thanked: 75 times
Unless you have a vacuum line leak downstream of the purge valve the car should run just fine. It really doesn't give a crap about the evap system as it is running.
The EVAP system is purely for the greenies.
Volvich
- Year and Model: 1998 Volvo C70 Coupe
There are two white check valves just after the purge valve, one upper from the T connector another to the right. One of them is stuck open on mine, I can blow through it both ways. Can I use a generic check valve there? Or they are made of specific "vapour resistatnt" materials?
I'm having P0440 code, and my purge valve looks pretty dead. I can blow through it, and it does not react in any way when I apply 12V to it. The previous owner had it changed like two years ago, but I don't think they changed the small filter. Also I think this faulty check valve could shorten it's life too.
- 53 Replies
- 7348 Views
Last post by theWIFES_S70
- 497 Views
Last post by jjmtjordan
