Fuel door hinge replacement?
I had someone attempt to steal fuel from me recently....in broad daylight no less!.....while shopping at a large mall. The fuel door was literally ripped off and tossed (which I found after a short search) but it is completely broken off the hinge, a little black plastic piece. Now, I have tried to see how the heck this thing is attached, thinking I could get the piece and replace it myself. I have gone in thru the trunk....can't access it, there is a double-walled fender there. I have taken the rubber insert out around the fuel filler cap area....can't access it, the gap between the double-walled fender is only about a 1/16" wide. This is driving me crazy! I guess I will have to have a body shop check it out......grrrrrrrr!
'99 S80 T6
'93 RX-7
Two cars. Four turbos. Gotta love it.
'93 RX-7
Guest
hinge bracket is held in place by four small plastic dowels.
find a nail or something slightly smaller diameter as the pins and drift them out with a hammer.
open the holes out a little on the replacment bracket and the pins hammer / push in much easier.
- 433 Views
Last post by E Showell
- 652 Views
Last post by Templin113
