Oil leaking from turbo
TurboMoose
Year and Model:
Post by TurboMoose »
Hello group! I just bought my first Volvo today! I love it! It's a 97 850 GLT with 118K. Looks to be extremely well taken care of... however there is a rather big oil leak coming from the turbo. It is not the oil return line, but the oil feed line. And I have no idea which line that is. Can anyone shed some light on this with a few pics? I took a few but have not figured out how to post them yet... help with that too would be greatly appreciated! :lol:
-Nathan
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Hi there...I know this thread is from awhile back, but I had an oil leak I was trying to trace...ended up being a bad alum. washer on my drain pan plug, but in the process I was up in and around the turbo and notice that the intake area (not the area connected to the exhaust) is covered with oil. I may have the same problem as you do....any help appreciated. Is this normal? There is no oil dripping down on the pavement at all from this area (probably why I haven't noticed it before)...just a film of oil covering most of that area including all the hoses...it appears wet. I'm concerned because I drive 100 miles a day to and from work and oil on a hot surface could be dangerous, right?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
Check your oil cap's gasket. This often is the culprit of top-down leaks.
Also -> Amazon link
MadeInJapan
Not a top down leak...appears to be from the smaller pcv system hoses or the charge air hose. How do I get in there to deal with this?
White850Turbo
Year and Model:
Post by White850Turbo »
MadeInJapan wrote:Is this normal? ?
Yup, you'll also find a film of oil all over the inside of your intercooler piping. Take this as a good sign though as it means that your PCV system works :wink: .
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
