intermittent Gas smell
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
hheaton
Year and Model: 2000 S80
Post by hheaton »
Hi, I have a 1994 960 wagon with 235k on it. Has been a great car with little problems. (Yes, I did just post another issue!)
The car has a very strong gas smell that is intermittent. There does not seem to be any rhyme or reason to the odor. I could walk into the garage first thing in the morning and it may smell very strong, or not at all, but then 20 minutes into driving the smell shows up. Does not seem to matter how full the tank is, or what the temprature is outside. I have run rosin paper the length of the car in the garage and marked where I park; there have only been a few small drips about the center of the engine compartment. I use an independent mechanic with a very good reputation, and he can't find anything. He thinks I should not be driving, due to possibility of fire, but it is my only car, so I am anyway-
Any ideas would be appreciated!
Thanks!!!!
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Did you check for a fuel leak with the engine running?
1988 Volvo 760 Turbo Wagon
hheaton
Post by hheaton »
Yes-
The only thing I have (possibly) seen, is 'wet' at the end of the fuel injector line. I ran rosen paper the length of the car so I could check for drips, being careful to park in the exact same place. The only drips (just a few) were just under the area by the power steering fluid compartment. This area is where the fumes are coming from, not by the injectors-
Thanks for any and all input!!!!
