I have the PPC code reader; works great on my 2004 S60. I got it after I inadvertently set the SRS light on while fixing the turn signal switch in the steering column. It can clear the SRS/Air Bag light, as well as other things. Dealer wanted minimum $200 to check/clear the light.
Here is the link, check e-bay etc.
http://www.ppc-diagnostic.com/info/
PC Diagnostic System! The diagnostic tool is developed by BSR and it can both read and erase DTCs (Diagnostic Trouble Codes) and it can also reset the service reminder lamp (SRL). Its compact format makes it easy to use and carry around. PPC Diagnostic System is connected to the diagnostic outlet of the car (OBDII).
PPC Diagnostic System works with all Volvo from 2001-2007.
Exceptions:
S80 1999-2006 works
S80 D/D5/TDI 1999-2000 does not work
C70 98-05 does not work
S/V40 96-04 does not work
SRS airbag service restet
skeeter123
- Year and Model: s60, 2004
