05 xc90 2.5T Timing Belt
Danilosilni
Year and Model: 2005 XC90 2.5T
Post by Danilosilni »
Im coming up on 98k miles. Correct me if i am wrong but for my vehicle i "should" change the timing belt, tensioner, and idler pulley at 120k miles. My question is when do you guys think i should change all that, and whether or not i should change the serpentine at the same time since there is no mention of that in my service book. Thanks!
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
We do them at the dealer @ the 105K service. and yes do the serp belt at the same time.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
jimmy57
Been thanked: 320 times
Post by jimmy57 »
It is a good idea to do the water pump also. The T belt drives it and it might last to 210K miles but Atlantic City Bookmakers would probably spot you bad odds for that one.
TexasCoder
Year and Model: 2004 XC90 T5 AW Tran
Post by TexasCoder »
Trust me, once you tear down into that far, you are going to thank yourself for replacing the "serviceable" parts at that time. You do not want to spend a day putting a new timing belt on, and then 10,000 miles later find out your water pump is going bad. While you got it all out in the open knock out the water pump, belts, tensioner & idler pulley(s) and don't forget about the thermostat (you dont have to do a tb job to change the thermostat, but since you are going to flush the coolant, if you replace the water pump, might as well put a new one in). Hope this helps, and the job is not hard, just take your time, and follow the directions and you will be fine. Let us know how the project comes out!
MixEngineer
Post by MixEngineer »
Does anyone know if they're are torque specs for any of the bolts/nuts for the timing belt replacement job? If so, I would like to know what they are.
Thanks!
I have a 2004 xc90, 2.5t, awd.
