central lock system failure?
nsm1701
Year and Model: 2002
Post by nsm1701 »
2002 XC70
Power window failure, central lock failure, and fuel filler door will not open. There has been a constant clicking from inside the driver side door. Checked the fuses and don't think that is the problem. Took inside door panel off and disconnected central lock buttons. This stopped the clicking. Do I need to replace this unit? If so, where do i get one and approx what do they go for?
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
You need a new driver's door switch. This switch is more than a switch, it is an electronic module, that makes it more expensive and has to be mated to the car by the dealer.
Used ones might or might not work, but if you are going this route try year specific replacement.
nsm1701
Post by nsm1701 »
thats what I figured... how expensive? ( just put put a transmission in last year and really getting fed up w/ car)... does the new or used module need to be prgrammed? If so, who does the prgramming?
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
Try http://www.erievovo.com/ or you can look on ebay as well. My guess on price would be between $50 and $100 depending on where you buy it. The dealer or other shop with the appropriate equipment would have to program the module. I've changed a few of these and some will work without programming and some won't, don't know the rhyme or reason as to why or why not.
nsm1701
Post by nsm1701 »
Thanks. Just got a quote from the mechanic. He said the module was about $400. plus another 100$ or so to re-program. Does that sound accurate?
jda2000
Post by jda2000 »
a new switch/module needs to be reprogrammed by the dealer or shop with VIDA hookup. The module you can get online new, much cheaper, but the local dealer won't allow you to bring your own part.
Ask the indie shop if you can bring your own part and they'll reprogram, o/w you're screwed and got to pay.
