Air Fuel Ratio Gauge Install
Easiest and most efficient way to install gauge? how should i get it through the dash...? Im blind here...
Hey buddy so the way I've always put things through the dash/fire wall is to get an old style metal coat hanger and make it as straight as you can tape one end of the wire to it. And then come from the engine bay side and look for the wiring loom that go's through the fire wall and follow that path. Be careful you don't want to puncture any rubber grommets that will let water to the inside of your wagon. I think if you look on the passenger side of the engine bay you'll see a wiring loom in hard plastic casing that's where I would start looking first. Just take your time you do not want to snag any wires or anything like that...
