Air Fuel Ratio Gauge Install
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
zooplane
Year and Model: V70 2003 N/A
Post by zooplane »
Easiest and most efficient way to install gauge? how should i get it through the dash...? Im blind here...
flylow
Year and Model: V70-T5,2001
Post by flylow »
Hey buddy so the way I've always put things through the dash/fire wall is to get an old style metal coat hanger and make it as straight as you can tape one end of the wire to it. And then come from the engine bay side and look for the wiring loom that go's through the fire wall and follow that path. Be careful you don't want to puncture any rubber grommets that will let water to the inside of your wagon. I think if you look on the passenger side of the engine bay you'll see a wiring loom in hard plastic casing that's where I would start looking first. Just take your time you do not want to snag any wires or anything like that...
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
+1
This is the easiest way to do this.
