lower control arm ball joint
yeagermeister
Year and Model:
Post by yeagermeister »
what's the trick to getting the lower control arm ball joint bolt out?
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
Jot
Year and Model: C30 2010
Post by Jot »
On the back side there is a seperation in the casting that needs to opened with a hammer and fork or chisel. Once seperated (very little) the bolt can be removed.The bolt will not move because when tightened the casting is distorted and is bending (very slight) the bolt
yeagermeister
Year and Model:
i'll try that. i couldn't get the bolt to turn at all- is it possible it's seized?
(the other) sean
'94 855 5-speed
