I bought a '98 S70 T5 this past winter and it had snows on it. I noticed what I thought was tire noise (low frequency) that doesn't change when I drop it into neutral so I don't think it is related to the transmission. Just put a fresh set of Goodyears on it and have the exact same noise, especially at just over 40mph. I'd think maybe wheel bearing but the noise is much lower frequency than what I've typically associated with a wheel bearing (higher pitch, grinding and metalic).
I did recently replace the passanger side axle due to a bad CV joint. Appreciate any ideas.
S70 Wheel Noise
JRL
- Year and Model: Several
- Been thanked: 16 times
Wheel bearing(s)
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Did everything go back together smoothly?
Perhaps a dustsheild got bent?
I would take the wheel off and spot check everything, dont remove stuff, but check to see if anything is touching.
but with what jrl said. maybe it is just your wheel bearing starting to go.
Car has 119k on it. It was making the noise before I replaced the axle, thought it was just tire noise from the snow tires, but have the same noise with new rubber put on this week, and everything went back together fine when I replaced the axle. Guess this will be a good excuse to also replace the axle/trans seal that is now leaking slightly from when I replaced the axle when I pull the wheel hub(s) to replace them. Odd, my '95 850 that I drove for 300k never had any of these issues.
EstVolvo
- Year and Model: 2000 V70
I have a similar thing going on. 2000 V70 111000 miles. The noise gets louder on curved highway ramps or after driving 10 minutes or so. Seems to be common failure on S/V70. I had also good luck with my previous car when it comes to wheel bearings (and many other things). 300000+ miles and maybe it would be still running, but the body started falling apart after 23 years.
What kind of wheel bearings should we get as a replacement?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
FAG bearings are the OEM manufacturer, but you can get them for about $50 cheaper than the "Volvo" branded ones.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
E14 I believe. I found some sockets at Autozone for $5. Sears wanted like $50 for a set.
'98 S70 T5
- 2116 Views
Last post by FLXC90
- 1261 Views
Last post by WillieEvans
- 11 Replies
- 1471 Views
Last post by Blacklab467
- 856 Views
Last post by Cees Klumper
- 1179 Views
Last post by Ou2mame
