S70 Wheel Noise
Dave123
Year and Model: '03 S80, '98 S70 T5
Post by Dave123 »
I bought a '98 S70 T5 this past winter and it had snows on it. I noticed what I thought was tire noise (low frequency) that doesn't change when I drop it into neutral so I don't think it is related to the transmission. Just put a fresh set of Goodyears on it and have the exact same noise, especially at just over 40mph. I'd think maybe wheel bearing but the noise is much lower frequency than what I've typically associated with a wheel bearing (higher pitch, grinding and metalic).
I did recently replace the passanger side axle due to a bad CV joint. Appreciate any ideas.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Wheel bearing(s)
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
Did everything go back together smoothly?
Perhaps a dustsheild got bent?
I would take the wheel off and spot check everything, dont remove stuff, but check to see if anything is touching.
but with what jrl said. maybe it is just your wheel bearing starting to go.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
What is the mileage?
Dave123
Post by Dave123 »
Car has 119k on it. It was making the noise before I replaced the axle, thought it was just tire noise from the snow tires, but have the same noise with new rubber put on this week, and everything went back together fine when I replaced the axle. Guess this will be a good excuse to also replace the axle/trans seal that is now leaking slightly from when I replaced the axle when I pull the wheel hub(s) to replace them. Odd, my '95 850 that I drove for 300k never had any of these issues.
EstVolvo
Year and Model: 2000 V70
Post by EstVolvo »
I have a similar thing going on. 2000 V70 111000 miles. The noise gets louder on curved highway ramps or after driving 10 minutes or so. Seems to be common failure on S/V70. I had also good luck with my previous car when it comes to wheel bearings (and many other things). 300000+ miles and maybe it would be still running, but the body started falling apart after 23 years.
What kind of wheel bearings should we get as a replacement?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
FAG bearings are the OEM manufacturer, but you can get them for about $50 cheaper than the "Volvo" branded ones.
'98 S70 T5
2016 Chevy Cruze Premier
EstVolvo
Post by EstVolvo »
Groton sells Optimal brand front wheel bearings - what to think about those?
Who sells FAG bearings?
Maybe I better stay away from the original brand since they lasted so little.
Dave123
Post by Dave123 »
Anyone know what size the torx bolt heads are on the back side to get wheel hubs off?
jblackburn
E14 I believe. I found some sockets at Autozone for $5. Sears wanted like $50 for a set. :shock:
'98 S70 T5
